For sale i have a Dynojet Quickshifter in perfect working order Works in both push or pull (road or race) shift Also for sale i have the QEM, which is the quickshifter expansion module. Needed if you only have the PCV on its own They are out of stock of these also. https://dynojet.co.uk/qem-10-quick-shifter-expansion-module https://dynojet.co.uk/4-130-quick-shifter-pull Price is for both but will sell separate If you wanted better mapping then QEM is ideal and gives you the option of QS at a later date. OR if you have the units to connect QS already then that's perfect too. Also the QS will work with HRC loom £235 for both £150 for QS £100 for the QEM
