My Mrs bought me my Brembo clutch lever and perch for my birthday next week and some carbon bits. As you know, the clutch lever is already fitted, but the carbon stuff came today. No point wrapping it i said - I better get it fitted..... I did have a problem fitting the L/H side tank panel and have actually cracked it
Lovely, I am waiting for mine to turn up from zero limits, who did you get yours off ? Any tips on fitting ! Other than don't crack it Your mrs is mint
Cheers Jamie. Got mine from GB Moto. the Heel plates fitted fine, although I did have to open out the holes to fit the bolts through. The RH tank insert fitted OK. You just need to slot it over the tabs first then line up the hole where the screw goes in. Im not sure what happened on the LH side. I did have to do a bit of fettling as the screw hole would just not line up. I got it really close then just applied too much pressure and it cracked. Its only small but I guess it will get worse?
Update - spoke to Barry at GB Moto this morning. Told him I had managed to crack the tank side panel. He has told me to send it back and he will replace it FOC! Top bloke!
How much did u pay for them mate? I've a 2009 repsol blade and looking to buy something nice, any ideas any1?
paid £75 for the tank panels and £30 for the heel plates. My replcement tank panel showed up the othe day. Fits great. Defo recommend GB Moto
