Electrical Socket ?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Ratser, May 9, 2013.
  1. Ratser
    Ratser Well-Known Member
    Anyone fitted one of these to their bikes before ?
    I only ask because going to the TT again this year, and finding a socket to charge my phone is a bit of a pain.
    It also seems that charging phones over there takes 4 times as long as it does here.
    So, anyone ever fitted one ?
    Any recommendations as to the best kind ?
    How easy are they to fit ?
    Is it 12 volt ?
    Totally clueless in this regard.
    Many thanks in advance.
  2. martinowen
    U can get USB 12v sockets, ideal as most things have USB cables with them these days
  3. chinny
    chinny Member
  4. Ratser
    Cheers guys.
    Although the thought of linking that to the battery and power switch is a little daunting to me.
    But as they say up here in Scotchland, that looks "the very dab".
  5. martinowen
  6. stevebetts
    stevebetts Well-Known Member
    ive got a cigarette lighter type socket that plugs into lead from may battery for the maximiser. dead easy to connect lots of things then.
  7. Ratser
    The one on the site that Chinny put up is cheaper than that one mate, but thanks for the link.
    Also might just be a better option to go for the one Steve suggests, as it could charge a multitude of things then rather than just a USB.
    But I will think it over.
    Electrics and mechanics are not my strong point though.
  8. martinowen
    It will prob be 2 wires 1 to each side of battery and an inline fuse
  9. Ratser
    Cheers guys.
    Seen a couple of different ones that are very simple to connect.
    Thanks all.
  10. Bart
    Bart Active Member
    I charged a laptop and phone off the bike in Portugal last year, no problems at all. It was just a cheap cigarette type socket off ebay and it lived in the boot/tail.
  11. Ratser
    Ok so I got one of those Bike-It double USB sockets for under my seat.
    One question and one problem.
    The quick connector isn't long enough to go from the battery to under the rear seat for easy connection. Are there extensions for these things ?
    And when it is connected it glows blue on the USB port. I am worried that if it stays connected that it will drain my battery.
    Will it ?
    Cheers and apologies if I sound a bit stupid.
  12. el-nicko
    el-nicko Well-Known Member
  13. Garyb
    Garyb Moderator.
    I had mine working all the time Ratser, even when parked for an hour sat Nav phone camera was on charge, go sign of it pulling anything out of the battery, I would say the HISS light drains more?
  14. Ratser
    Cheers Gary.
    Will connect it tonight then, and try it tomorrow with it having been on all the time.
    Much appreciated mate.
  15. sinewave
    You're all best going for the Optimate USB Charger lead.
    Yes it's more dollars at £23.50 from Tweeks's but it's quality kit, comes with adapters, it reaches fore and aft (shipmates! :p) and has a built in cut off if power drops below 12.7 volts or whatever it is so you'll always have enough juice to start her up.
    The 'Cigarette lighter' unit Niko is soo last decade and very large and cumbersome compared to a USB lead of which everything nowadays has that connection.
    It also looks cheap shyte and wouldn't take much for those connections to short out and burn ya Blade to the ground.
    Doubt your insurance company would pay out if you've fitted a £3 electrical device with ZERO safety features to ya 10K Bike either?
    O-102 SAE USB Charger Lead (Ignore the price, tis far cheaper through Andy O at DT)
    #15 sinewave, May 22, 2013
  16. el-nicko
    You're frightening me now, you are.:eek:
  17. sinewave
    Good!
    Take it from me, I'm a Sparks, amongst other things.
    That Fag Lighter ebay link is a Bag-O-Wank! :rolleyes:
  18. Repsol Rob
    Repsol Rob Elite Member
    i thought id spend £9.99 on a "Belkin" usb charger and lead all boxed from a ebay seller............first car charge on my new iphone 5 and i noticed smoke bellowing out of charging port.....shit !! anyhow phone thank fuck was ok but lead had melted !! seller said "somtimes componants break in transit" bloody twat ! so replaced goods with "Griffin dual usb charger and lead" one port charged and other was nt wired !!!!! i ve been lucky trying to save a couple of quid..........Buy from an offical outlet and just accept these acccesories do cost at times !!
  19. sinewave
  20. el-nicko
    OK, but who's Andy O at DT?
    BTW, I've got one of these fitted at the moment...
    #20 el-nicko, May 22, 2013
