Electricians?
Discussion in 'Lounge' started by Barry_m2, Jan 18, 2013.
  1. Barry_m2
    Barry_m2 Active Member
    Anyone on the forum a domestic electrician?
    I have a question about wiringing in lights in the kithen.
    Cheers
  2. kpone
    Wiringing? You type lke you've been drinkinging Barry.
    Blaggers would be your man but he's lying low at the moment.
  3. Repsol Rob
    Repsol Rob Elite Member
    What the prob.... ? run my own electrical contracting business ????
  4. Barry_m2
    Ha, oops, that was before the pint too!
    Well, having a false ceiling put in and putting in spots instead of the standard single fitment in there at the moment (bulb, not strip).
    I will be putting in 10 spots, but want to know, do I need a transformer or anything for them, or do I just wire them in parallel from the existing lighing point?
  5. Repsol Rob
    Well it all depends what size lamps you will be using and how many other lights are on the existing circuit......eg...50W lamps will be 500watt load i would be careful just sticking in willy nilly 10 more fittings....we use 3watt led bulbs so at only 30Watt would probably be less than original lamp ?
    Transformer might be required if you use 12volt fittings ?......sounds like you need a Sparky !! hence the reason for Part P requirements !!!!!!!!!!!!!! to prevent DIY disasters !!!!!!! :D
  6. Givover
    Part p and Blaggers Now thats the way forward.Ps WTF is he ?
  7. Barry_m2
    I'll be using LEDs, so it all depends on the voltage of the bulb then as to wether I need a transformer?
  8. Repsol Rob
    No..... some are in the form of a GU10 style of lamp and dont need transformers....... generally its Drivers not transformers used to power LEDs but personally i would go for the GU 10 style of lamp...... as all bits are built into lamp....
  9. Repsol Rob
    #9 Repsol Rob, Jan 18, 2013
  10. Repsol Rob
  11. kpone
    Well done Rob. I bet you can't wait for your gift basket to arrive from the admin.
  12. Repsol Rob
    Tyre Warmers please Ken ! lol.....................
  13. kpone
    If you let Blaggers near your wiring you wouldn't need them.
  14. Repsol Rob
    If Blaggers is still using any rubber in his installations........ then he will be a part P Blagger !!
  15. Barry_m2
  16. Repsol Rob
    Well that type of lamp works with one transformer per bulb.....
  17. Barry_m2
    Just checked the fitments I brought a while back, IP65 12v.
  18. Repsol Rob
    Well as i said before.....watch the load (ie total wattage)
  19. sinewave
    I do Commercial work mostly (clues in the username) but have been known to dabble in Domestics under duress from friends & family. :rolleyes:
    JCC LED 7's are by far the best IMHO, got em in our gaff, along with a fully addressable Fire Alarm system! :cool:
    JCC
    :D
    #19 sinewave, Jan 19, 2013
