I've got a working engine in bits the roller bearing at the input shaft had some play is the reason it's in bits crank and everything else is fine with no marks gears were fine the input shaft is knackered but everything else is ok i would of rebuilt it but I put in a 2015 engine the engine is out a 8k 2011 bike if anyone needs any bits get in touch cheers
