Engine cut out/fuel pump prime
Discussion in 'General 1000RR Discussion' started by Jonboy, Aug 28, 2015.
  1. Jonboy
    Jonboy New Member
    Hi guys
    Need some advice,on a few occasions when turning on ignition, no whirr from fuel pump can be heard and more worryingly last night when out for a blast,engine cut out completely @ about 8000rpm, and for about 5 mins wouldn't restart as no fuel pump noise?
    Any ideas?
  2. Scott
    Scott Active Member
    Loose wire ?
  3. Scottmurray2890
    Scottmurray2890 Active Member
    Possible immobiliser fault. Does the hiss light come on at same time. Check wiring from antenna to multi plug further down the line
  4. GappySmeg
    GappySmeg Well-Known Member
    Have you checked the kill switch? (Not that I'm suggesting you're numpty enough to have accidentally hit it, but that they can start playing up and need replacing)
  5. Jonboy
    Jonboy New Member
  6. Jonboy
    Jonboy New Member
    Def no HISS lights staying on,reckon it could be to do with Meta alarm?
  7. Scottmurray2890
    Possibly mate I'm unfamiliar with the alarm and if it cuts fuel pump.
    Only so much will disable fuel pump, immobiliser and kill switch as someone said.
  8. Troys7012
    Troys7012 Active Member
    maybe corrosion in the ignition switch wiring,bad connection at rear of switch.
