Engine management light translogic Quickshifter?
Discussion in 'General 1000RR Discussion' started by Dom, Jul 3, 2020.
  1. Dom
    Dom Active Member
    Hi, I’ve fitted a translogic quick shifter today and also refitted my racefit exhaust. Started it up to make sure the quick shifter was working and I’ve got a check engine management light about 2seconds into the bike firing up.
    Do you reckon it’s my O2 sensor in the exhaust or the quick shifter?
    Quick shifter seems to work as far as I can tell on the paddock stands. Haven’t test ridden it because of the engine management light... I’ll see if I can upload the video below... nope, will only let me upload a photo...
    Any help would be much appreciated. Thanks
    Dom
  2. Dom
    Dom Active Member
    It was just staying solid, so I thought if I take the o2 sensor out and start it I’ll see what it does then. Wouldn’t stay running... so put it back in and now it’s flashing twice at me whilst it’s running... any idea’s?
    There looks to be a little nick there but would that effect it? 3221C520-401E-4F8F-8AB3-B8B78CA5644E.jpeg
  3. leigh
    leigh Active Member
    did you sort it ?
  4. Dom
    Dom Active Member
    Yeah, I missed a vacuum pipe connected to the map sensor.
  5. leigh
    leigh Active Member
    I did exactly the same thing mate couldn't work out why it was running rough and engine management I even refitted the translogic thinking I had done it wrong
  6. hitch
    hitch Elite Member
    Oof, I bet that was fun :(
