Hi all, my mates EML is flashing when he revs the bike a RR10, any ideas and how do you interrogate the fault and or code? Thanks Neil
By counting how many flashes and then seeing what that matches up to but I don't have the table sorry. U tried disconnected the battery for a while. Sometimes the simplest things work
As Scott says count the flashes. Each long flash is 10 and each short flash is 1. If it doesn't error all the time you may need to short the diag socket.
