I have just taken a standard can off with the servo cable disconnected and put on an Akra with the same cable disconnected but now I'm getting the engine management light flashing. I don't know if it makes a difference but it's flashing slow twice then fast 3 times straight after, its running very lumpy Sewell nowanyone have any ideas what I have done or can do to correct it pleases I need the bike first thing in the morning Cheers
havent touched the servo wheel steve since i took the yoshi off,and didnt get the light with the standard can and no cable attached,i spoke to a garage and they have told me to run it up to temp then let it get cold and repeat 3 times and that should re-set it. got to replace the battery so will do an ecu re-set after that and see if that does anything? just worried if it will do ant damage if i use it ?
I take it this is now sorted? The code it was giving you would be 23 I believe. It'll say somewhere in the manual what it's for.
23 is O2 sensor IIRC... sounds to me its been removed from exhaust change but not plugged back in ...
Turned out to be a broken wire in the lambda sensor, have deleted it now and lights gone off. Thanks for the replys
