Epic fairing removal fail !!!!
Discussion in 'General 1000RR Discussion' started by PauloHRC, Jan 27, 2018.
  1. PauloHRC
    PauloHRC God Like
    Today I am officially Manchester's maddest man!!!
    In 16 years of tinkering with bikes I have never had so much trouble in taking off a bikes fairings. I was attempting to fit my new GB racing engine covers, to do so you need to remove the fairings. To be fair I didn't have much time, only about 5 hours o_O but an hour in an I resorted to watching videos on you tube and still couldn't get the job done!!
    Why have Honda made this such a difficult task?? In the end I rang Hunts for advice and they told me to bring the covers in (while laughing at me down the phone) and they'd fit them for me when the bike goes in for a service next Wednesday. Big thanks to Scott who offered to do this, but I would still like some tips for future reference as I'm possibly buying a spare set of bodywork for track use.
    Needless to say I will be drowning my sorrows tonight and the Mrs will probably get a bollocking over something minor as well haha :confused:
  2. Lozzy
    Karma for saying tall screens were shite last night :rolleyes:
    • Funny Funny x 2
  3. PauloHRC
    PauloHRC God Like
    I just laughed out loud at that Lozzy!
    I didn't say that did I?? :eek:
  4. dainesefreak
    dainesefreak Senior Member
    I think shorter wavy ones are OK though. :p
  5. Ian E
    Ian E Active Member
  6. Lozzy
    Oh yes indeedy :D
  7. nigelrb
    Gee. I had enough dramas just with the belly pan!! Those bleedin' tabs and slots - who came up with that idea?
  8. PauloHRC
    PauloHRC God Like
    Tell me about it.....im going to have another crack at it next weekend and if that fails I'll leave it to the pro's!
  9. dainesefreak
    Have you tried a hack saw and a hammer? ;)
  10. PauloHRC
    PauloHRC God Like
    I very nearly got the hammer out believe me!!
  11. Iain
    Iain Active Member
    There is no need to remove the fairing to fit GB covers, just remove the bottom Allan bolts so you can ease the fairing out a bit.
    Which model year do you have, and does it have ABS?
  12. PauloHRC
    PauloHRC God Like
    Hi Iain......its an '09 non ABS. When I started I didn't think it was going quite so difficult and I wanted to do the job properly so the fairings were coming off.
    Now you've mentioned that it would be worth a try....is that how you did it?? I'd still like info on how to do it for future reference though, cheers.
  13. Iain
    Iain Active Member
    Yes, mine is a 14, but all I did was undo the bottom fairing bolts.
    I did find the ABS cover would not fit properly after, so I removed it.
  14. thewiz
    thewiz Active Member
    I usually take the side fairing off with the ram air tubes and covers all in one piece. Undo the side bolt on the fairing, remove all the pushpins near the radiator. Remove the inner ram air cover ( 3 push pins), remove the one bolt that connects the ram air to the head fairing. Once this is done, pull the whole fairing and ram air off the bike. easy mate.
  15. PauloHRC
    PauloHRC God Like
    2014 models have different fairings to the 09 models, the engine covers are much more exposed on yours mate.
    Still worth a try but there are definitely a few bolts completely covered that couldn't be got at just by bending the fairing out a little.
  16. Great Guy
    Great Guy Well-Known Member
    Once the fairing bolts are off, you can literally "yank" the inner black plastic parts near the brake and clutch levers off .
    Tip, get some new black fairing screws ( 3 types) from Honda for when you put the fairing back on.
  17. Slick
    Slick Elite Member
    On the 08-12 the clutch side 2 of the cover bolts are a pain, easier to remove the fairing.
    You'll get used to it, once you know which fixings need removing you'll whip the feckers off in no time
  18. CBRGav
    CBRGav Active Member
    Glad I'm not the only one lol I removed mine for the first time took longer get the side panel off than it did get the air box out LMAO. Fit back on well though once on
