Has anyone fitted an EvoTech Tail tidy to a 2011 blade, if so did you have to modify the undertray? Cheers
yup just be carefull with the tabs on the seat unit easy to snap but look amazing when they are on got one on my blade
It's a straight forward job, if you extend the indicator wires using solder to enable the join to fit into a length of flexible conduit then use wire connectors under the seat connect them under the seat
