Evotech tail tidy Question
Discussion in 'Mods, Upgrades, Accessories and Products' started by Remal, Feb 27, 2013.
  1. Remal
    Quick question. how is best to fit the original indicators to this tail tidy. I ask as my R&G one had a small home for the bolt and another for the wire. the Evotech one has a large hole that I can only think will need a large wash to ensure the indicator fits tight
    Any other idea's?
  2. phantomx0_1
    phantomx0_1 Active Member
    Best idea is to get some Gucci rizoma items and bin the bulky originals!
  3. Remal
    well just looked at their website (Evotech) and seems I should have had some plastic blanks to add to the other side. Will have to double check later if I have over looked them or if they did not come with my order
    I'm happy for now with the original lights
  4. Carl
    Carl Well-Known Member
    They do have plastic spacers mate, get on to Evotec I'm sure they will help you out. I have an Evotec on mine, it looks better than the R&G but you need to think outside the box on the indicator wire's
  5. Remal
    I phoned them and found out the plastic spacers I did not have was as i had the R&G tail tidy and they do not use the original rubber mounts that I did not think of. so removed from the original rear no plate mount and going to finish it off tonight
    Doh
  6. Carl
    Extend the indicator wires with solder and join them under the seat with connectors you can then use wire covers from the back of the number plate and into the seat, tidies them up nicely image.jpg
  7. Remal
    Is that a Ozzy pic?
  8. Carl
    I posted it upside down so you could see the wiring underneath ;)
  9. Freedom of choice
    Or any dodgy git reading the number plate before you re edit the picture Carl.
  10. Remal
    done it tonight, looks neat and not noticed much, heat shrink and some tape hides away most of the wires out of sight, and the rubber mounts fit much better now I got them
  11. niknack
    niknack New Member
    what about intergated indicators n brakelight led s i got mine in 2009 n now u can pick them up anywhere no rubbish indicators makes back end look 100 % better
  12. Si.
    Because 9 times out if 10 you can't see the bikes fitted with them indicating. I personally think they be shit dude.
  13. thezipsteruk
    thezipsteruk Elite Member
    I was all geared up to do mine today only to find out about the giant holes!!
    Im so peed off, nothing is open all weekend, I have rizoma indicators and evotech tidy.
    The indicators just go straight through the standard holes as they are so big and it looks like most of the indicator will be hidden behind the number plate unless i buy a plod pulling mini plate.
    How did yours fit in the end Remal. Did you have to buy indicator adapters for the holes and then spacers to move them out.
    Im starting to think I like the original scaffolding now!!
    Thanks for any help, where did you get your spacers in the end?
