im pretty sure the exhaust system changed on the 2013 bike but does anyone know if it’s the same on the 14,15 and 16 bikes please as I’m not sure what year bike I’m getting yet and don’t want to pass up a good opportunity on a full system. Cheers
Definitely bigger link pipe on the '15 mate. I ordered the wrong (2013) model SC Project and the link pipe was not only diff diameter there is an O2 sensor plug that screws in on the older model
I've seen similar, Raph, but can't help definitively. When the 'after work' gurus like @tuktuk and @Gaffa22 come on line you'll get your definitive answer!
08,09,10,11,12,13 = 50mm headers 14,15,16 = 60mm headers If you after full system - it makes no odds. They fit all the same. Even 17+ full system will bolt onto 08 for example. As full systems never changed only headers did on road bikes due to emission rules etc over the years. If you fitting full system you may need the rear lower exhaust bracket to the frame (by rear shock linkage) that on standard bikes. Depends on full system mounting bracket (year they make if for if they list that way) on the exhaust and what year bike you got as you might have it already. But basically its simply 1 bracket which can order from honda so no need to worry. Buy any full system from 08 upwards it will fit.
@Blade runner 1 , they're the best looking set of rear sets I've seen on a bike. Fit in well with the black frame, but also not an over abundance of holes to be seen. Great choice!
Did a fair bit of research before buying these. Not the biggest amount of adjustability, but spot on for me.
