Exhaust Fitting
Discussion in 'Mods, Upgrades, Accessories and Products' started by MadG, Jun 26, 2014.
  1. MadG
    MadG New Member
    I have bought a Racefit Black series with end cap and baffle for the bike. Is there anything I should be aware of when disconnecting the exhaust servo? Do I disconnect the Lamda sensor or just unscrew and count the turns. Bike is an ABS model.
    Thanks
  2. sps170373
    Make sure if you twist the servo that you return it to its start position otherwise it might throw up a fault code, I got and exhaust servo replacement module and took off the servo, just count the turns you twist off with when taking the lambda sensor off or get a blanking plug and O2 eliminator
    good choice of exhaust mate, love mine.
  3. MadG
    MadG New Member
    Thanks, do you have a baffle installed and do you get any unwanted attention?
  4. sps170373
    I have a baffle that I sometimes put in :D depending where I'm going, have ridden past police with it out no problem, wasnt giving it the beans when I did though ;)
  5. MadG
    MadG New Member
    Thanks for your help, was quite easy. Hardest part was figuring how to take off the servo cover on the ABS model. Even with the NRI inserted its loud, very loud :eek:
  6. GBCS
    GBCS Active Member
    Are you sure it's the Black Edition ?
    When I ordered mine, I was told that the Black is "as is" with no option for an extra baffle. The growler can take the extra baffle ( or so I believe ). I went for the black anyway, as I think it looks superb.
    I fitted mine this afternoon, and it's the loudest pipe I think I have ever heard !
    Absolutely Amazing !!! :D:D:D
  7. MadG
    MadG New Member
    P1000690.jpg Yes it is the black edition, but they put the growler end cap on it to accept a baffle. Even with the baffle in I find it loud, but nice :). Glad you are enjoying yours.
    #7 MadG, Jun 30, 2014
