Exhaust flap opening after 4000rpm
Discussion in 'General 1000RR Discussion' started by Trackit, Jun 21, 2022.
  1. Trackit
    Trackit Active Member
    I've put all the standard fairings, exhaust etc back on my 2015 model, trackdays were becoming a little too epensive for me given the present financial chaos.
    I want to run it with the exhaust flap standard, ie it opens as the revs increase. I reved the bike to 5000 rpm whilst on its stand and in neutral but the flap remained closed.
    Does it only open if it's in gear and rpm above 4000 rpm or should it open even when in neuatral and above 4000rpm?
    I could disconnect the cable and have the flap permanently open but I like the quiet exhaust.
  2. Coda
    Coda Active Member
    Afaik it only opens when in gear. I had mine on a stand and I couldn’t see it open when revving the bike.
  3. Iain
    Iain Active Member
    You need to be doing around 50mph before it opens when in standard settings.
  4. Jez
    Jez Senior Member
    normally it is a way of getting through noise tests so may not open unless in gear
