Exhaust Help wanted
Discussion in 'General 1000RR Discussion' started by Dorsetdave, Jul 16, 2012.
  1. Dorsetdave
    Dorsetdave Active Member
    Hi Guys,
    I have the new 2012 Blade and fancy getting the Yoshi end can for it. My question is, do Yoshi make a can that has the cat, valve and Lambda sensor thread. I want the can for looks not really for performance and would like it with baffle in so its not too loud.
    I dont really want a power comander or remap, just the original map with the new end can.
    Any advice most welcome,
    Thanks Dave
  2. Pinkster1000RR
    Pinkster1000RR Active Member
    Ive got the Yoshi on my 2011 Blade and it has the Lambda sensor thread, all i did was un screwed the sensor from the old end can and popped it into the new end can. and as for the valve for the exhaust it's not required, just dissconnect it.
    Jay
  3. MrB
    MrB God Like
    Just fitted a full akrapovic system to my 2012 and so far running fine. no probs disconnecting the exhaust valve and has a thread for the lambda. go for it.
  4. megawatt
    megawatt Well-Known Member
    You can buy the Lambda sensor threads. If it's M12, I have a couple.
  5. Dorsetdave
    Hi Jay,
    so did you have the one with removable baffle. When the original can is removed is the cat still left on the bike.
  6. phantomx0_1
    phantomx0_1 Active Member
    Get the yoshi disconnect the O2 sensor and fit an O2 elimiator and run that sucker without the baffle! Let her scream and remember loud can saves lives!
  7. Jamiestrada
    The Cat is removed from the bike when you fit the Yoshi Dave. I think most of the Yoshi cans all come with a baffle, as do the Akrapovic.
  8. phantomx0_1
    Have you posted up pictures of your bike yet? We all crave pictures !
  9. martinowen
    If its just for cosmetic reasons that you want a new exhaust
    Try eBay 130485160578
    It's only £78 and it's a carbon cover that goes over the original exhaust so won't be loud or need tune up etc
  10. martinowen
