ok guys I have searched to see if I can get an answer to this but hoping some of you track riders can help me. This winter I intend on fitting a new exhaust system / quick shifter /adjustable rear sets and a rempa to suit the exhaust. Now I am looking at this beautiful full system from Yoshimura it comes with a baffle, my intention is to be able to turn my bike in to a track bike maybe after next season so the mods I do now are with that end goal in mind. Can anyone advise on whether or not they know if an aftermarket system like this with the baffle is likely to pass a 105 DB track regulation? http://www.jhsracingstore.co.uk/PBSCProduct.asp?ItmID=9597365 Any advice on this or suggestions for other models would be greatly appreciated.
I've got a yoshi end can on my rr and without baffs it registers at 99db once you've fitted it go along to a track and get them to test it
With a baffle you shouldn't have any trouble at tracks with 105 dB limits. But a lot of tracks are less that that these days and it's only going to get worse. I would invest in suspension and brakes instead
I have a r77 end can only on my road blade and it was loud! I havr since tracked the blade and put the baffles in but it was not passing noise tests. I had to pinch the baffles and it just passed at 100.5db
Such a difficult thing to figure out the sole reason to change my exhaust is so I can track my bike but without knowing which will be suitable is a real pain, Does anyone have any advice on adjustable rear sets as well which ones are good or not ?
