Explain this Power Commander lark to me?
Discussion in 'Mods, Upgrades, Accessories and Products' started by sinewave, Jan 22, 2013.
  1. sinewave
    Pro's & Cons? :confused:
  2. Si.
    Pros :
    1. sorts out the fuelling PROPERLY and matches can to air/fuel if you have a custom map.
    2. Increased MPG (in my case)
    3. You can match it to baffle in and baffle out with different maps so better optimised bike for both occasions.
    4. More performance, although not loads more.
    5. Smoother feel in the rev range, and an all over smoother bike
    6. Eliminates flat spots in the delivery.
    All imo anyway.
    Cons:
    1. Nothing, apart from the cost of buying it and having a custom map.
  3. Repsol Rob
    Repsol Rob Elite Member
    Ditto........
  4. Remal
    look at the BAzzaz also , I'm using it and love it
    bazzaz.co.uk
  5. sinewave
    I assumed it'd be sumat along those lines.
    I'm well versed in Car mapping as I've had both my previous vehicles done with good results, my current car is a Merc E320 CDi Sport Estate which has been mapped and it flies, comparatively that is!
    So does the PC let you alter maps on the fly so to speak and what sort of money is a custom map and dyno set up on a Blade?
  6. Dano28
    Dano28 Active Member
    Agreed don't see any cons...have had one on my bike since Aug last year but not ridden it yet (it's a track bike) hoping to have it dyno'd and set up early this year so I'll put a post up on it.
  7. Si.
    You can alter maps if you load them on with a laptop. IIRC, the PCV can only let you switch maps on the fly with an extra accessory though which plugs in to it.
  8. phantom
    phantom Active Member
    I know one con,
    they dont come already fitted on the bike :)
  9. Gblade
    Gblade Active Member
    Si who did your maps? And how much are you looking at for that? Thinking if this myself.
  10. Si.
    Steve at Motrac mate. He fitted the PCV and custom mapped for £150, took ages as he blanked of the PAIR too and did a few other bits.
  11. sinewave
    Motrac eh?
    Just up t'road from me!
    How feckin convenient is that then? :cool:
