So Iv been failing noise test on ride by at snetterton. I thought about trying a design like this years wsb blade. Called mhp to improve the setup I had so I can hopefully run without a baffle and pass noise test The baffle was also sucking some power from tuned engine which was a shame wasting the horses This is where I am now , akro heads and decat. Mhp link pipe extended can and hangar Hope u like it Just to add it's expected to be about 100 db without baffle which is about just right I hope
There was nothing wrong with it in the first place just a bit loud and I had to use a baffle So hope now no baffle needed
Perfect it's 99 static and doesn't trip the ride around meter. All without baffle so I got to use full power for the first time. Got the one man band out. It sounded better than it did with a stubby pipe. I could hear it popping while I was cruising down paddock hill. Well chuffed if u can't tell
Hi Scott.Can you PM the cost as well?Now I have akrapovic evolution system and it makes 102 with the baffle.
