Factory shock settings for a 2014 shock?
Discussion in 'Maintenance' started by edderby, Jun 6, 2020.
  1. edderby
    edderby Active Member
    Just had a low miles 2014 rear shock fitted to my 2008 blade. Please can anyone tell me what the standard factory settings are (I only have the owners manual for the 2008). I'm OK with the preload as there's a paint mark to show, but I'm not sure about the compression and rebound.
    Might try and adjust settings to suit me, but would like to start with the standard set-up
    Thanks!
  2. John Tuck
    John Tuck Active Member
    If it’s the balance free shock.......see the attached.
  3. edderby
    Brilliant - you're a star John- thanks very much that's exactly what I wanted to know.
    I assume any old flat screwdriver will do the job in absence of the "Honda BFR adjuster"?
    Silly me - went to look at the bike again and saw why I can't access the screws with a normal straight screwdriver...
    But the screwdriver blade on my penknife works perfectly and all back to factory settings now.
    #3 edderby, Jun 6, 2020
  4. John Tuck
    You’re welcome. Yeh, I didn’t get the Honda tool either and just use an angle driver.
  5. Kentblade
    Kentblade God Like
    I used these settings, admittedly on a 14 Blade with matching forks. Weight around 75KG and good settings for fast road over standard
    MY12-15 Showa Big Piston Forks Modified
    Front Compression 7.5 Turns back from Full Clock (Hard)
    Front Rebound 3.0 Turns back from Full Clock (Hard)
    Front Preload 5.5 Turns in from Full Anticlock (Soft)
    Rear Compression 3 Turns back from Full Clock (Hard)
    Rear Rebound 2 Turns back from Full Clock (Hard)
    Rear Preload 6/10
    MY12-15 Showa Big Piston Forks Factory Setting
    Front Compression 5.5 Turns back from Full Clock (Hard)
    Front Rebound 4.5 Turns back from Full Clock (Hard)
    Front Preload 7.5 Turns in from Full Anticlock (Soft)
    Rear Compression 2 Turns back from Full Clock (Hard)
    Rear Rebound 2.5 Turns back from Full Clock (Hard)
    Rear Preload 4/10
  6. Iain
    Iain Active Member
    There is a slight difference in the rebound settings between 12/13 bikes and the 14/16 ones:
    2012 Standard Settings
    Front Rebound 4.75 Turns back from Full Clock (Hard)
    Rear Compression 2.75 Turns back from Full Clock (Hard)
    Rear Preload 4/10
    2014 Standard Settings
    Rear Preload 4/10
  7. edderby
    OK thanks very much Iain. Mine shock is a 2014, so I might change it by half a turn to match.
  8. Iain
    Iain Active Member
    Give it a try, I had a 12, and now a 14, and put mine back to the 12 settings just to soften it bit for UK crap roads. It all depends on your preference and riding style, but its easy enough to change back.
  9. edderby
    Cheers, I'm old and slow (see my videos in the touring section!) so I'm more likely to favour "smooth ride" over "elbow down"!
