Fairing question
Discussion in 'Mods, Upgrades, Accessories and Products' started by pablo, Jan 22, 2012.
  1. pablo
    pablo Active Member
    I've made a start on removing all my bodywork off the bike and fitting the new Chinese kit.
    I need to put the pads from the inside of the standard fairing sides onto the new, the originals were stuck down with some double sided adhesive sheets, what's the best adhesive to use to swap them over????
    Thanks in advance...
  2. dan.1moore1
    I wouldn't pull of the pads in case you ever want to reuse them ,Your choice of course but i would Make new ones for the new kit . Double sided tape from B&Q and what ever you can find to pack out to the same thickness .
    If your deffo binning the OE kit then any decent adhesive should do , They aint going to get much abuse
