Fast action throttle
Discussion in 'Mods, Upgrades, Accessories and Products' started by Alen, Dec 28, 2018.
  1. Alen
    Alen Member
    Hi guys,
    For mounting fast action throttle on cbr 1000 rr sp 2014 do I need to buy new cables or it is possible to use original ones?
  2. nigelrb
    I haven't put a quick action on for a while and not sure about Domino, but you should be able to use your present cable. It'll probably just need a tad of adjustment as provided for on OEM cables.
  3. roboticus
    roboticus Active Member
    I had one on my ninja and had change it, I think u can get a throttle tube of a r6 that fits straight on a blade, save some money too
  4. mgoode180566
    mgoode180566 Active Member
    i have fitted the HRC tube that you can get from ebay, i used the standard cables, now have a 1/6 th turn from closed to fully open
  5. roboticus
    even better u can say u got something on your bike with hrc on it
  6. tuktuk
    tuktuk Elite Member
    I just bought the HRC throttle tube, no other parts required. There is enough slack in the cables if you adjust them at the throttle body end.
    Best mod £ for £.
  7. Alen
    Alen Member
    :)Thank you guys, helpfull as always!!!
