Fast indicator flash
Discussion in 'Mods, Upgrades, Accessories and Products' started by rewy..rr, Sep 3, 2013.
  1. rewy..rr
    rewy..rr Active Member
    Just replaced the standard size rear indicators, to micro ones, but flash rate now twice as quick as normal, assume I need some sort of relay to slow flash rate down, what do I need and where does it go.
    Thanks
  2. Carl
    Carl Well-Known Member
    You need an in line resister mate, be careful where you put the though, they can get hot?
  3. F1reblade
    F1reblade Active Member
    If you've got the 04-07 blade then you need to change the relay (which is between the headlights and a bit of a PITA to get to)
  4. iang27
    iang27 Active Member
    I fitted two of those small gold heat sink resistors. Fastened them to the metal seat catch plate to help dissipate the heat.
  5. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Usually a flash relay that is required but if you order one make sure it has the correct number of pins for the connector, sometimes they can be the wrong connector fit.
  6. scooby
    scooby Elite Member
    this,although a relay is easier(but more expensive) to sort the issue.
  7. phantom
    phantom Active Member
    also be careful with the resistor route, some can get real hot if you
    have the flashers on too long which can melt nearby stuff as I found
    with some gold heatsink style ones I got on ebay.
    I went the relay route with this bike using this unit
    LED flasher relay Honda CBR 600/1000 RR Fireblade | eBay
