Anyone got the fault codes for a 2013 blade. Took it to cadwell and it ran like a bag of shit, its flashing 2 long 3 short. Thanks
Haynes specifies the engine fault code 23 is meant to be "faulty oxygen sensor heating element." Although there is some disparity from Haynes to the actual honda manual, as haynes class the way to identify the code is the long flashes identify the first number then short represents second so using there way the code 2 long and 3 short is termed 23. Where as honda manual class it as error code 2-3 which is not listed anywhere closest is 2-1 which is a map sensor performance issue. Possibly split or dislodged pipe going to map sensor in airbox. As shown in above pic.
