A bit of advice please My 06 trackbike is flashing up codes 23 and 34 I have only ridden it once and to be honest didnt notice it was showing the codes I believe they are to do with the oxygen sensor and exhaust gas control valve The bike is running a full scorpion system so not standard, its also had modifications to the wiring etc I dont thing its anything to worry about, can anyone confirm its all ok Cheers Rob
It just sounds like when whoever unplugged them they did not fit a servo eliminator or OS eliminator. Both available cheaply enough on evilbay. You just need to make sure it has been mapped to the full exhaust so it is not running lean.
Thanks It run fine on its fist run out, it has a pc and has been mapped and dont appear to be running lean Cheers Rob
