6X17 from [https://www.fowlersparts.co.uk/parts/4821757/cbr1000rra-2010-e-hrc-mkh/front-wheel] 8 x 24 from [https://www.fowlersparts.co.uk/parts/4821760/cbr1000rra-2010-e-hrc-mkh/rear-wheel] so its M6 x 17 - correct for the front and M8 x 24 for the rear does anyone know the thread size - basically I need a set with flat heads rather than the allen key set as I want to put an IRC TC system on. is there a specific type of bolt also - i.e. strength / stainless etc? thanks Jim
thanks Scott but I am after buying replacement bolts that you dont have the allen key to tighten up. Its for a traction control system that counts the bolt heads and they need to be flat headed. I just want to confirm what I need to buy first! cheers Jim
Oh sorry scott. Where did you get them from? How many spares have you - I need a full set. Bikes booked in for Monday and forgot to get these! Do you know the thread pitch? Have you irc fitted? If so how do you find it?
I,have loads will have to check if they are magnetic first cause been told they aren't. But was sure they are. I will try sort it tommoro and get the magnet out. I have loads spare. And sure I have some rears.yes I have irc but it hasn't worked since I got it and it's in the shop trying to get fixed so I really don't know. Did u get easy or pro version
Bought it off TDR (early powerslide version) I think ive seen your posts on their with the probs you have had if that is you. its booked in with pete oulton OTC dyno. If nick and him can't do it I certainly cant! Ill let you know how I get on. If you let me know if you find any. thanks jim
No problem scott thanks for taking the time to look. Anyone got a supplier of ferrous stainless steel bolts? Apparently thats what I need and am drawing a blank at the moment :-(
