Fireblade sbk parts nova brembo oz febur motec
Discussion in 'Parts, Accessories & Clothing' started by Daznorthwest, Aug 15, 2018.
  1. Daznorthwest
    Daznorthwest Elite Member
    I have some parts available from a 2013/2014 Bsb fireblade superbike
    please phone or text with any questions /offers for a quicker respsonse. All items are in excellent used condition 07706326464
    shot blasted Bsb spec frame with adjustable swimgarm pivot points and spindle £600
    ohlins 220 mm stroke damper £150
    superbike engine with Hrc clutch and spring . Rebuilt by bob Farnham ,Stage 4 billet cams ,Nova gear box, Hrc valves and springs , head work , porter and flowed approx 194-198 bhp depending which dyno Covered approx 500 miles . Lovely motor and very fresh £2500
    Full Motec m170 ECU licencesd current Bsb spec ( just been checked with the serial number)
    Motec sl3 dash With Carbon surround and Hrc clock bracket to mount , motec loom with aerospace duestch connectors
    Motec gps, etc connectors , map switch , pit lane and air bleed via Bosch all enabled , hm
    Quickshfter Also wired in Harness is ready to bolt on as it’s been removed altogether £4000
    febur radiator , febur oil cooler , speed flex hoses and Samco engine and rad kit set £1000
    titanuim arrow world suoerbike system and baffle ( long ten kate silencer supplied for quiet days )£900
    Hrc mel billet linkage and plates £250
    k tech dds pro rear shock £575
    airbox and throttle bodies £75
    hrc QA throttle £60
    Gb engine cover kit sold
    brembo 19/20, hel lines, res snd lightech span adjuster £250
    mwr air filter £50
    kit genny , rota and cover sold
    ali Hrc bellmouths £300
    52 mm renthal clipns , tubs and rizoma lever guard £100
    17 inch oz piega r wheels , 330 mm brembo discs and rear has sprocket carrier and disc plus spacers £1200
    new rear Hrc subfrmaes and battery tray with Hrc rectifier bracket to mount on the generator cover £275
    new front Hrc sunbfrmaes and electrics bracket also available price to be confirmed
    All prices include post ( except motor )
    Discount available for collection on all
    Many thanks
    I also have other stuff on eBay . Please click on the link and check out my other items
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/323384672773
    #1 Daznorthwest, Aug 15, 2018
  2. Spygoat
    Spygoat Well-Known Member
    Good luck with your sale mate, nice parts you've got there.
  3. Daznorthwest
    Cheers buddy many thanks
  4. Lifeofriley
    Lifeofriley New Member
    Pmd about steering damper.
