First time seal cleaning ?
Discussion in 'General 1000RR Discussion' started by Jefo, Jun 1, 2022.
  1. Jefo
    Jefo New Member
    My left fork tube is slightly wet on my '04 blade. Not dripping but wet.
    As i have spend more than i can the past two months being in debt now getting this bike on the road i really have nothing more to spend for the next 8 months at least.
    Whether it is going to work or not its my one and only chance to just maybe get a temporary fix .
    My best gamble i reckon is to try my best to clean the seal.
    I have read this can be done using a thin plastic material i just want to run the procedure by anyone who has tried it on a blade ? Mine a 2005 model.
    1st
    On the upside down fork.
    Can i leave the bike on the sidestand or rear stand when doing this ? I dont have a front stand.
    If it would be ok to leave the bike with the fork on the bike while doing this ?
    2nd. So the idea is to remove the dust seal with a flat screwdriver.
    Then i reckon with the bike's own weight on the fork the stopper ring and seal will be somewhat higher up ?
    3rd
    Should i just leave the stopper ring alone and pry my piece of plastic past the stopper ring by feel and into the oil seal or do i have to remove the stopper ring ?
    4: will a lot of oil come out when i push the plastic piece inside the oil seal and do a full circle to try and move possible dust/debris out of the way.
    Does this sound ok ?
  2. warren smart
    warren smart Active Member
  3. Jefo
    Jefo New Member
    Ok thanks i will get the tool, on the 1000rr there is a stopper ring below the actual oil seal after removing the dust seal does it need to be removed ? And will it be exposed enough to remove with the bike resting on its fron wheel ?
