After taking oem brake and clutch levers found i cannot get the sleeve/bearing out, none with the pazzos,these where push out items on my K6 gsxr Can anybody help. ?.. Many have changed levers so someone must have had this problem Rr8 by the way Thanks in advance
My sleeve on the clutch lever literally fell out. Theres nothing to hold it in once you take the lever out. You then just put the sleeve in the pazzo lever, mine went in perfect. Pictures might help?
Joe; managed to press out sleeves, holes in pazzos are too small for sleeve in clutch lever, brake lever hole perfect fit for bolt without sleeve this looks like i have levers for a different model meaning a steel bolt thru ali is not good. Could you read off the part numbers off your levers. ???J
My blades stored at my parents, I can get the number for you tomorrow when I go round. Although thinking about it i'm not sure i recall seeing any numbers (mines on an rr4) Will certainly look tomorrow for you though mate.
They will not be the same Joe. Seems they are just the wrong levers for the rr8, the sleeves should fit in the holes, clutch bolt hole too small, brake hole only big enough For bolt.
