Fitted the quickshifter box and ran the cables over the weekend. The PCv was just wedged under the seat with not enough room for anything else so I decided to make up a special mounting plate for both units under the seat hump. Cut, shaped and sprayed it and then mounted them side by side. Cables now are loom wrapped together and running neatly under the seat and out to the various locations.
