Guys, I tried fitting my PCV a couple of weeks back, got as far as taking up the tank to remove the 3 connectors underneath, the middle line is the fuel line (green) it would not come off for love nor money, I spend 40 minutes trying with my fingers in all different position, I even carefully tried to use pliers a few times but it would not budge whatsoever. Has anyone else had this problem and if so is there a way around it I've missed? TIA.
What u r doing is right. There just very fiddle the main fuel pipe has like a vacuum on it so just need to push clips in and i twisted mine so clips didn't keep falling back in slots. Also if u get a friend to help and take out two bottom bolts on tank and lift it up it gives u a bit more room.
I see, I didn't want to break it so I sacked it off in the end, I had my mrs helping me which is not the best really. I'll give it another go later.
