Fitting OEM Silencer
Discussion in 'Mods, Upgrades, Accessories and Products' started by guitaryellow, Sep 30, 2017.
  1. guitaryellow
    guitaryellow Active Member
    I'm taking my Akra off and putting the original back on, the Akra was main dealer fitted. Question is will the Lambada sensor still be there hanging somewhere?
    Regards
  2. Ian E
    Ian E Active Member
    The Akra I had on my 2012 used the original Lambda sensor. If you don't have one on yours it's probably been removed?
    Make sure you have the foil gasket if refitting the original exhaust (the Akra doesn't use a gasket).
  3. guitaryellow
    Thanks I didn't know the sensor also went on the Akra, not sure about the foil, it's going Monday, so no time if not there.
  4. guitaryellow
    Just checked it on eBay then went out to check and it's all there. Thanks for pointing that out.
  5. bonjo
    bonjo Active Member
    the road legal akra had bothe the valve cable and O2 fitting for 08> before the CAT was moved to upstram of the silencer. After that, I don't know
    • Friendly Friendly x 1
  6. guitaryellow
    Many thanks I've fitted it now, the Akrapovic will now be up for sale. Great advice on here, helped immensely.
