Fitting R&G Crash bungs
Discussion in 'General 1000RR Discussion' started by Pete H, Jun 17, 2013.
  1. Pete H
    Pete H Active Member
    I want to fit some r&g bungs to my rr6 and I know that means drilling the fairing panels to get to the mounting point, but can anyone tell me if the kit comes with a template or how do I work out exactly where to drill, I'm hoping its not something like chalking the mounting point and seeing where the fairing touches it on the inside.
  2. Carl
    Carl Well-Known Member
    There's a number of ways, when I did my RR 5 I used an Allen key the same diameter as the hole in the engine mounting bolt, passed it through with a dab of white paint, worked very well for me.
  3. Muffking
    You don't get a template. I unscrewed the engine bolts one at a time, marked them with a dab of paint, refitted the fairing and pushed against the bolt to mark the inside of the fairing. That way you can drill a pilot hole from the inside and check it lines up with the bolt ok before using the big drill.
    Alternatively you can use a sanding wheel on a Dremel to widen the hole, applying extra pressure in one direction if the hole is off centre.
    #3 Muffking, Jun 17, 2013
  4. IcarusGreen
    IcarusGreen Elite Member
    As above, small pilot hole to make sure it's central before drilling the larger hole
  5. sinewave
    The latest kits include a pointed head bolt thingy that goes into the main frame engine bolt which then presses against the inside of the fairing and leaves a marked point visible on the outside of the fairing.
    You don't need to remove the fairing, just loosen it.
    Then CAREFULLY drill a pilot hole from outside to in, once you have a pilot hole then you use a Cone cutter to enlarge the hole to the required size, simpleesssss!
    What's to fuck up bar slipping with the Pilot drilling? :eek:
  6. Pete H
    I am so looking foward to doing this now.
    What could possibly go wrong :eek:
  7. coupe312
    coupe312 Active Member
    that exsactly what i think keep putting it off
  8. sinewave
    U pair of Pussies! ;)
    Coupe, if ya can Twat a Bike Thief then this will be a walk in the park! :cool:
  9. coupe312
    i have hands of a wrecking ball not for delicate work.....
    i think it fear of cocking up my fairing or more to the point i'd have to admit it on here
  10. Muffking
