Flasher relat
Discussion in 'Mods, Upgrades, Accessories and Products' started by TerryHawk, May 9, 2014.
  1. TerryHawk
    TerryHawk Active Member
    Flasher relay
    Hey guys,does anyone know how many pins there are on the flasher relay on a 2009 blade please,
    Am fitting some rizoma led rear indis and want to get the correct relay to sort out flash rate,
    Many thanks
  2. Womblewizard
    Womblewizard Active Member
    Looking at drawing, turning signal relay - 4 pins dude!
  3. TerryHawk
    Thanks mate that'd great.didn't want to pull the nose cone off til I had to. Thanks again
  4. thezipsteruk
    thezipsteruk Elite Member
    the Rizomas will come with relays matey!
    Mine did anyhow :)
  5. Barstewardsquad
    Do you mean resistors and not relays?
  6. TerryHawk
    Hi mate,they did but seemingly I need to use both,2 per side,seems like an awfully untidy solution,just thought relay
    might be easier,luckily womblewizard came up trumps with the 4 pin answer,cheers
  7. TerryHawk
    Got the resistors but rumour has it the relay change does the job mate
  8. thezipsteruk
    you are right they were resistors, and you are right again using rizomas spec for hondas means using both sets of resistors.
    BUT
    i tried one set and they flashed the same amount as two sets!?
    stll v bulky tho, glad i could hide in the boot lol
  9. TerryHawk
    Outstanding,I'll give one a go. I think I cld live with that but two would look awful and
    let's face it there isn't much space to start with
