hi! i got a PC3 cheap and i also won an auction on a Quickshifter ! some say you cant use a Quickshifter on 8injector bikes without a module... that's a LIE! There is some software called PCShiftKillEnable that can make your PCIII able to adjust kill times so the Shifter Works! Yes the PCIII alone will give kill times. I got a friend with 08 fireblade running PCIII + Quickshifter without Module and works fine. The problem is that i think PCIII will give Fueling Kill times not Ignition. Is there any damage caused if during the fuel kill times the ignition keeps firing?
I wouldnt use that for toffee, say bye bye gearbox if you do. if the ignition keeps firing, the engine keeps rpm, your clattering gears & dogs against each other.
