Apart from the colours, any differences between the forks? Want to get rid of brown lowers, so looking to fit the rr6/7 ones in my 04. Thanks!
They are slightly different, the 06/07 are different where the calipers joins so the can take the spacer for the bigger discs. I found this out when looking at using the 06 spacers on my 05 Basically when you take the calipers off the 05 has a male end and if you were to look at the 06 without its spacer it will have a female one if that makes sense
Nope I had to get some ones that would made for the 05. To be honest prob cheaper just to powdercoat the current ones
