fork oil
Discussion in 'Maintenance' started by Liam Robertson, Jun 10, 2016.
  1. Liam Robertson
    Liam Robertson New Member
    2009 trackbike and want to service the forks with new seals and fresh oil, but what oil should i use ???
  2. Nigelg79
    Nigelg79 Active Member
    Silkolene RSF 7.5 in my standard 08. Excellent quality fluid with high viscosity index (VI) rating. Make sure you check the weight of the fluid to see it is the best option for you and your weight, and also for the fork internals.
