Fork preload adjusters?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mr OCD, Apr 1, 2015.
  1. Mr OCD
    Mr OCD Well-Known Member
    Anyone recommend some?
    Must be black ! :)
  2. Slick
    Slick Elite Member
  3. exuptoy
    exuptoy Elite Member
  4. exuptoy
    I've had an Oberon master cylinder pot cap and oil filler cap in the past and been very happy with the quality.
  5. ColinBR
    I found them to be a gimmick. As Slick says you can't actually use them unless your swinging from them.
  6. exuptoy
    Maybe so but when you've ruined yours by adjusting them with anything other than a feather duster at least they'll cover your hand fisted damage! :D
    My old Gixer K3 ones were mullered but they looked mint with anodised blue adjusters fitted!
  7. ColinBR
    That's why u wanna use some paper roll or the likes between the nut and socket.
    I also fell foul to the anodising on previous forks getting damaged when adjusting the preload before.
  8. Mr OCD
    I use masking tape ... but a small bit slipped and marked the preload nut slightly hence was looking into the adjusters to avoid it happening again.
    But if they are just useless bling I won't bother. The whole point was to be functional!
  9. Millsp1
    Millsp1 Active Member
    Try Titax, quality
  10. Mr OCD
    But are they useable ?
    I like bling ... But it's got to be bling that works :)
  11. Millsp1
    They work fine, grub screw tightens them up, different colours available as well.
