Im going to be doing the fork seals on my mates 07 blade tomorrow. Is there anything in particular I need to know before doing these regarding the blade. Ie anything in particular to look out for. Thanks
There are some tools for usd forks that are handy I have one to help pull the spring down and lock in place so you can undo the lock nut that holds the caps on..then another to hold the damper rod to pull through the spring to redo it..
