forks and back shock settings
Discussion in 'General 1000RR Discussion' started by clivo69, Jan 26, 2016.
  1. clivo69
    clivo69 Active Member
    Hi all anyone out there about 12 stone got there shocks set up for an 08 blade they would like to share
  2. exuptoy
    exuptoy Elite Member
    Do a search on here mate. Plenty of advice on here.
    Do yourself a favour first tho, set up your preload to suit your own weight and don't take preload advice and hope it's right. It's easy as long as you have a mate to help with the measuring. I suppose base settings are ok but you can fine tune yourself once they are near.
  3. clivo69
    Cheers dude
  4. exuptoy
  5. Shutty
    Shutty Well-Known Member
    Had mine set up for me, 14st, best thing I ever did, frt end is so smooth, but I did do a fork oil change too as an 08 and never been done
  6. sulaco
    sulaco Active Member
    If you don't want to pay for a setup, start at factory standard and work from there, just trying a few tweak's. Honda are usually pretty good with the factory settings. Factory settings work great for me ( 13 stone full gear ) Did on my 600f4i, 929 and current 1k 2005
  7. clivo69
    Thanks all
  8. rebel
    rebel Active Member
    2015-07-18 12.30.08.jpg that's 13st kitted up
  9. clivo69
    Cheers man just a couple of clicks away then
