Forum Upgrade
Discussion in 'Forum Announcements' started by Rob, Sep 30, 2012.
  1. Rob
    Rob Administrator
    Hi all,
    Tonight the forum will be upgraded to the latest software version. This will add a number of improvements.
    There may be several interruptions in performance tonight.
    Just a heads up .
    Rob.
  2. Remal
    Thanks for the heads up Rob, Could you look into why I get this when I press the media link at the top of the page
    ou do not have permission to access this page. This could be due to one of several reasons:
    Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
  3. kpone
    It appears to be working as advertised for me Matt.
  4. Remal
    Not worked for me or Dan for over a year
  5. Rob
    Rob Administrator
    Matt, must be something I sett incorrectly when I added you and Dan as mods. I'll check it out asap.
  6. Rob
    Rob Administrator
    Matt, try now?
  7. Remal
    Holy crap for the first time I see it
    cheers Rob
  8. kpone
    I don't feel updated......
    I've still got my flares, my platforms,........my mullet...
  9. arthurbikemad
    He likes to tinker does that Rob, where do you get all these updates? you on forum monthly or something...
  10. Rob
    Rob Administrator
    Upgrade not completed yet - a bit more to do... maybe tonight.
  11. kpone
    You tease you.
  12. arthurbikemad
    Yeah bring it on, I've just set up three WRT54GL 1.1 APs at our yard running DD WRT firmware all with 9dB high gain antennas chucking out 251mW on chan 1, 6 and 11! I have 1mile long WiFi...Oh yeah baby!!! have some.....lol
  13. kpone
    You lucky, lucky bar steward. If I sit in the back room I have to be on the right hand side of the sofa. Left hand side, I'm in the wi-lderness.
  14. arthurbikemad
    Oh mate the Linksys WRT54's have been around for years, if hard wired and setup as Access points which is easy just turn off DHCP set its own IP and set all the SSIDs and passwords the same you can have seamless roaming WiFi where ever you want! All you need do is plug in your network cable from your router into the WRT and your off even with the standard firmware and antennas they work perfect! Best bit is you can buy then from eBay from 15.00! Enjoy :)
    Same as this
    http://www.ebay.co.uk/itm/Linksys-W...less_Routers&hash=item2c68904b23#ht_500wt_922
    there are many models but as I say standard is good for most house hold coverage.
    this is dd wrt firmware
    http://www.dd-wrt.com/wiki/index.php/Main_Page
    Get access to 1000rr.co.uk from anywhere in your house.. :D
    #14 arthurbikemad, Oct 1, 2012
  15. kpone
    Yeah, you see, I recognise that they were all words you just spoke, but that was about it mate.
  16. arthurbikemad
    If I can win you one cheap I will! I will set it up for you too... leave it with me.. :)
  17. samuk
    samuk Well-Known Member
    Looking good..have been away for 2 weeks just logged in and thought i had gone to the wrong forum..lol
  18. Remal
    Aid have been using the same router for years. Always seemed to work well
  19. Remal
    I have have been using the same router for years. Always seemed to work well
  20. Haggler ®™
    Haggler ®™ Active Member
    Q.............logged on tonight and instead of the page filling the whole screen all I,ve got is a bit in the middle??????????????
    Have you guys been fudging around again?
