front brake lines, standard and race setup
Discussion in 'General 1000RR Discussion' started by fez.57, Jan 8, 2012.
  1. fez.57
    fez.57 Well-Known Member
    I am wanting to upgrade my brake lines to braided hoses and run 2 lines direct from the master cylinder. do you have to make a modification to run the 2 hoses as the standard setup only has 1 hose running from the master cylinder and it has slightly confused me
  2. megawatt
    megawatt Well-Known Member
    Think you need a longer banjo bolt and extra copper washer into the M/C, two lines the same length and some p clips to stop em rubbing on yer mudguard. You can buy banjo bolt bleed nipples for bleeding at the M/C.
  3. fez.57
    Will those parts not come with the kit if you order the race setup
  4. megawatt
    Should do apart from the M/C bleed nipple.
  5. fez.57
    Ok thanks im sure i can find somebody who has 1 of those
  6. lee711
    lee711 Active Member
    #6 lee711, Jan 8, 2012
  7. Benn The Pig
    You get all the kit you need to do the mod with the lines you buy mate!
  8. JonnyAnnett
    JonnyAnnett Active Member
    All fittings you need come in our (HEL) kits. You won't need to modify anything to fit them tho :)
    You won't need a banjo bolt with bleed nipple. All 1000RR's have a bleed nipple built in, or should do anyhow.
    See the group buy we are running at the moment ;)
  9. fez.57
  10. fez.57
    yes i have already asked for some of them :)
  11. arthurbikemad
    Not quite sure what you would need the bleed nipple banjo for? For a start the master cyl banjo is upside down..
  12. megawatt
    Better to bleed the system from the M/C Arthur, sticks outta the banjo bolt head!
  13. JonnyAnnett
    But there is a bleed nipple already in the master cylinder so no need for the bolt with bleed nipple? All 1000RR's 04+ have a bleed nipple built in.
    Also if you don't have a bleed nipple, just slightly crack banjo slightly open for one pump of lever (cover with cloth) and that'll sort it also ;)
    #13 JonnyAnnett, Jan 8, 2012
  14. megawatt
    Masterblader with an RR4 reccomended em, don't do much with RR8 to 12s.
  15. dan.1moore1
    Radial MC's have 1 built in to the body already mate
  16. megawatt
    Dunno about the new fangled stuff, just the older stuff!
  17. arthurbikemad
    Done hundreds mate, like JA says just crack off the banjo bolt, but like I say the Banjo on the master is under the cycl is it not? And as said they have bleeders on the top of the master... :)
    Edit: just read your above post :)
  18. fez.57
    Is there any performance gain from using the race setup instead of the standard over the mudguard way ?
  19. JonnyAnnett
    It's very marginal to be fair. You do get slightly better brake feel and more equal performance from two full length lines when braking hard though.
