Front brake micro switch.
Discussion in 'Maintenance' started by Great Guy, Apr 4, 2017.
  1. Great Guy
    Great Guy Well-Known Member
    Mine is not functioning properly. Is difficult to fit a new one? How long to do?
  2. ColinBR
    2 minute job.
    Philips screwdriver and undo/redo wire clips. Job done
  3. blake7
    blake7 Active Member
    Have you tested it first with a multimeter? Need to check for continuity across the connections when pressing in the button
  4. Great Guy
    How do you get at the small phillips screw? Do you need an extra long screw driver?
  5. ColinBR
    It's underneath the brake lever assembly. A short screw driver is all you need.
    Have a look and see for yourself. It ain't hard
  6. Great Guy
    Located it. But I can't get enough purchase on it. Slightly worried about stripping the phillips screw. I think it must be "glued " in. I will try again today. If no success, then Mr Honda.
  7. Great Guy
    Sorted with the aide of WD40. Question, when I put the new one on, should I use some locktite?
  8. ColinBR
    No. Wouldn't bother with locktite mate.
