Front brakes binding
Discussion in 'General 1000RR Discussion' started by timmy twoshoes, Jun 18, 2012.
  1. timmy twoshoes
    Hi all
    Since I've fitted new front brake pads to my Blade they seem to be binding on. Though there doesn't seem to be a problem when I'm braking it's slowing the bike down fairly quickly when I throttle off. Should I of bled them ? Or am I missing something else.
    There was quite a bit of salt corrosion on the calipars, could this cause the pads to stay forward and not return?
  2. BLAGGERS
    BLAGGERS Well-Known Member
    in short, yep. Also, did you check the calipers slide freely on the pins?
  3. IcarusGreen
    IcarusGreen Elite Member
    A good strip down and cleaning of the callipers should sort it by the sounds of it.
  4. timmy twoshoes
    Looks like a full strip down tomorra if the weather good. Wish I had a garage
  5. BLAGGERS
    Same here mate. Crap innit?
  6. timmy twoshoes
    Well stripped them down today, cleaned all the crud off. Put copper slip on the back of the pads, greased the pins so the pads move freely. Bleeded the brakes added new brake fluid. Wheel spins but stops in the same place every time. I think the left hand disc might be warped slightly.
    Does anyone have 1 spare disc for sale ?
  7. BLAGGERS
    Oooh, bad result fella. If funds allow swap the pair for some bling wavy discs?
