Front loom
Discussion in 'General 1000RR Discussion' started by Dom, Jun 4, 2020.
  1. Dom
    Dom Active Member
    Hi, wondering if anyone can answer this question. Does anyone know if a front wiring loom from a 2011 ABS bike will fit a 2009 without abs? Headlight/clocks/indicators loom.
    Little bit about my current problem, had an off at cadwell last year. My clocks got ripped from the bike. Plugged them back in and the only things that work on it are the indicators, main beam and Hiss lights up when ignition turns on. Bike starts up fine but it doesn’t do the sweep, light up, tell me the mileage or even rev with the bike. The rev counter is stuck at 5.5k even when unplugged. I assumed it was the clocks that were broken. Tried 3 sets and they all do the exact same. Tried the fuses they all looked fine. Replaced them all just Incase, made no difference. Now I think it’s the wiring loom. Hence my question, would they fit and work? Part numbers are different of course but tracking down ones with the same part number if proving difficult...
    Hopefully someone can shed some light on my current situation. Thanks
    Dom
