Front & Rear Paddoks
Discussion in 'Mods, Upgrades, Accessories and Products' started by samuk, Jun 25, 2012.
  1. samuk
    samuk Well-Known Member
  2. Remal
    Great price but as you will be using them a lot and they should last years I love my Harris stands and would buy them again.
    But for the money they seem as if they will do a good job
  3. robinh73
    robinh73 Well-Known Member
    Can't go wrong really. For the money they look spot on. Go for it!
  4. fez.57
    fez.57 Well-Known Member
    Good price for a VERY helpfull tool.
    I only have a cheap 1 but it does the job. could use a front 1 aswell soon
  5. BLAGGERS
    BLAGGERS Well-Known Member
    I just bought a cheap pair, front and rear, from price busters. 42 quid, delivered. Shite, but they do the job.
  6. samuk
    is it easy to get the bike up by your self?
    also not sure if i would need a front..? rear i could use for when cleaning the bike etc..what use would a front be?
  7. BLAGGERS
    Piece o piss to lift them yourself. Front stand used for wheel removal, maintenance and cleaning. Also when the bikes gonna be stored its better to have the tyres off the floor to avoid 'flat spots'
  8. ahmedf
    ahmedf Active Member
    STFLV HEADSTOCK LIFT PADDOCK STAND SET FRONT AND REAR | eBay
    have this front headstock stand and comes with different pins for different bikes. find it much better than forklift ones on my 600rr. although i have a different rear one but £68 posted for this set. They sell the fornt one on its own for £48 posted
  9. Only1Matrixxx
    Only1Matrixxx Active Member
    I have a rear EvoKit paddock stand, as in OP...
    Does what it says on the tin, and looks pretty good too!!
  10. samuk
    thanks all, have ordered the EvoKit stands..
  11. binned_it
    binned_it Active Member
    They look great, and the rear works as well as it looks: very pleased, but I find the front one lifts a bit too high. It's a bugger to lift it too, because you have to lift so much, and it tilts the bike towards the back, so the dipstick reads wrong.
    But more stable than the nasty orange tubular steel jobbies I bought on offer from Busters or somewhere 10 years ago, and they dont scratch the swingarm.
    I also rate the headstock stands - mine is the motogp branded job: 80 quid on Amazon.
  12. scooby
    scooby Elite Member
    only problem with them is the rear doesn't lift the bike very high which can make warmers a bit tight
  13. shanes
    shanes Active Member
  14. martinowen
    Have a look at an abba stand mate with a front lift little bit more expensive but well worth the money, really stable and really quick and easy to use.
  15. Remal
    I use the biketec headstock stand on my blade with the Harris on the rear. cracking front stand
  16. ahmedf
    indeed it is. SO much safer too for the front. heard stories of the front slipping on normal fork lift ones!
  17. samuk
    Are these not meant to fit between the bobbin?
    It does not seem to be wide enough!
    Right side
    Left side
  18. samuk
    Ffs, I should have bought some decent stands..these look cheap..and don't even seem to do the job..
  19. BLAGGERS
    Ah, ya back then? ;) fast them repsols arent they?
  20. BLAGGERS
    Did they come with additional 'cups' ? The type that actually fit under the swinger?
