Front sprocket removal on 2007rr
Discussion in 'Maintenance' started by burden8tr, Dec 6, 2012.
  1. burden8tr
    burden8tr New Member
    Hi I want to change the front sprocket on the bike,the clutch cylinder on the side has to be removed,will I have to drain all the fluid before I remove it,I'm just wanting to remove the front sprocket for replacement that's all.dont want to remove the 3 bolts any have fluid spray every where.
    Thanks
  2. megawatt
    megawatt Well-Known Member
    You don't need to break into the hydraulic clutch system mate. Just unbolt the cover to access the sprocket and if you need to the slave cylinder retaining bolts .Lift em outta the way and then remove the sprocket.
  3. burden8tr
    Arrr thanks very much my friend been awaiting a reply,can now crack on,very much appriciated.
    Cheers.
  4. megawatt
    Do you know how to remove the sprocket? If not sure PM yer number and I 'll talk you through it?
  5. burden8tr
    Hi and thanks, been watching YouTube so should be ok with that got all the tools and a nice padded shaft for through the back wheel,torque wrench,lock tight,new renthal 16tooth for front gold and black super sprok 42 for rear,I'll get a did gold chain when a see a bargain,oh also got some gold titanium sprocket nuts,so should all look nice for next year all been well.thanks again may take you up on your kind offer sir should I get stuck
    Atvb
