Front sproket
Discussion in 'Maintenance' started by Itsafix, Apr 15, 2023.
  1. Itsafix
    Itsafix New Member
    Just changing my chain and sprockets never don’t one be four it’s just when I removed the original and put on the new one it seam like new sprocket is not tight on the splines and the retaining bolt tightens up to the shaft not the sprocket old one is the same but not as much movement is it normal?? It’s like a floating sprocket?? Bike is 2019 and replacement front sprocket is a super sprox.
  2. warren smart
    warren smart Active Member
    I had it on a gsxr and found the new sprocket I fitted was thinner than the original, it was a jt sprocket I fitted and ended up fitting a talon that was thicker.
  3. Coda
    Coda Active Member
    I’ve got a new JT -1 tooth front on my blade, I’ve not noticed an issue, I’m gonna have to check it.
  4. kev.b
    kev.b Well-Known Member
    The rental front sprocket on my Blade has a little side movement and the nut is tight. It's fine ,some replacement front sprockets fit like this.
