Frontr brake overhaul 04RR
Discussion in 'Maintenance' started by bandit_287, Jan 12, 2013.
  1. bandit_287
    bandit_287 Active Member
    Took the Blade out for a ride yesterday as it was a rare mild dry day and noticed when i dropped it from the paddock stands that the front brakes has stuck on a bit. I took it out for a few miles and put it back on its stands and span the front wheel and I'm feeling a bit of resistance from the pads. The wheel will spin a revolution and I can hear the pads dragging a bit so I thought I would give the front brakes an overhaul.
    Is this relatively simple to do? I just want to remove the pads and clean up and copperslip the caliper pistons.
    Any help/guidance is appreciated.
  2. eyore
    eyore Member
    Copperslip shouldent go anywhere near the pistons,it can be used sparingly where they bear on the brake pads, but lubricate the pistons with red rubber grease,anything else will/can/may damage the seals. Clean the pistons using a toothbrush and brake/clutch cleaner.
  3. bandit_287
    I didn't know that! Been using it got years lol. I've just ordered a tub from eBay.
    Many thanks.
  4. megawatt
    megawatt Well-Known Member
    Pump pistons out as much as you dare, one at a time, clean em till shiny, apply RRG near seals and push pistons back in by hand all the way in. If they won't push in easily, remove them all and check seals. Apply RRG to seals, push pistons back in and then bleed brakes.
