Hi anyone removed the fuel cap from a 2008 blade I took the tank off and was told that it is easier to remove the fuel cap to put it back on something to do with the rubber seal
Cap or tap? The rubber seal that sits around the plastic tank cover can be a pain but just rub some silicone spray or wd40 on it prior to installation and it goes on easily
vasaline and wd40 will perish the rubber seal mate use a RED RUBBER GREASE can get it from any car spares shop its purpose made for rubber
